Hi friends,
One more time a "battery story"...
As many others here, it happens I don't use my bikes for one or two weeks, or even more. So I had sometimes to use the "oldschool" spare car battery system...
About 6 months ago I decided to be more "modern-style", and bought a permanent battery charger from Richco in CNX. It is a CTEK 800 model (3000 Bahts and a perfect tool...) that can permanently care battery up to 32 Ah...
As I guessed it can be used on several batteries at the same time (up to 32 Ah), I tested this on my Yam Fazer (10 Ah lead-acid-MF batt) and my BMW F650GS (12 Ah lead-acid-open batt), so both are now cared by the same tender... And it works fine, no matter the difference MF/open-lead-acid, the CTEK is done for that...
I installed splashproof cigarette-lighter plugs on the 2 bikes for GPS, Mobile phone or whatever (I know BMW has a plug already, but it's a "standard" DIN one... not so "standard" IMHO, and I don't want to worry with an lost or forgotten or loosen adapter), did appropriate connection cables and put the CTEK 800 unit right under the roofing of the bike shelter not to have wires lying along on the floor, and go!
So this means I built 2 "detachable and independent" cables connected in parallel on the charger through cigarette-lighter plugs and sockets going to each bike...
... from the unit.
When going for a ride, I disconnect one bike and let the other one plugged... No matter, the charger goes on working...
When coming back, I just plug the bike back, and now forget... battery problems!
Besides, this type of permanent charger extends battery life... and, cherry on top of the cake, I get some 10 Ah capacity left-over that could be used for a third bike :wink:
Well, I don't know if this is useful here, but I post it in case of: I remember some previous posts about this kind of subject. And sometimes nothing is better than self-experience... At least, for the 6 first test months, it's perfect.
Cheers to all,
... from the unit.
Cheers to all,
